scale fuselage for GAUI Hurricane 550
Invité bmichels
Invité bmichels
- I am the HAPPY owner of a Hurricane 550. I am looking for a LIGHT and scale fuselage for my heli. I would prefer a MILITARY fuse. Since the Hurricane 550 is not really a true class30 size (its size is more like a swift or a Logo10), i can’t find fuselage that adapt well on the hurricane 550 :
- lengh = 106cm , r
- Rotor 110cm,
- main rotor to tail rotor= 75cm (can be reduced to 68cm using the short boom),
- weight 2 kg
Therefore, what scale fuselage (if possible a military fuse like Hugues 500/530, super cobra....) can you recommend that will be good quality , LIGHT, and fit easily on the Hurricane 550 ?
Thanks in advance
Bertrand MICHELS
PS: a Side question: I use the stock 850Kv motor and stock 500mm wood blades. What is the best combination (motor / pinion / blades ) for maximum fluing time ? If I change for larger blades, will I reduce or increase my flying time ? (I am NOT doing 3D).
