New from Scorpion . . . . multicopter motor and tools
The Scorpion Team continues to bring quality, high performance products to market. Introducing the latest motor in the M-40 Series for Multirotors and additional tools. continue through to check out the details.
New Released! Scorpion M-4010-400 kv motor for multi-copter!!!
Scorpion is delighted to announce our new M-4010-400kv! This motor specially made for multi-copter. This motor provides all the power that you can use, while still maintaining excellent efficiency and reaction, a perfectly balanced rotor.
It suitable for two types of propeller which has space 12mm screw hole and 6mm & 8mm inner diameter.
They are now available in M-40 series.
Scorpion M-4010-400KV
[M_4010_400]
$99.99
Specifications
Stator Diameter: 40 mm(1.57 in)
Stator Thickness: 10 mm(0.39 in)
No.of stator Arms: 12
No.of stator Poles: 14
Motor Wind: 10 Turn Y
Motor Wire: 13-Strand 0.25 mm
Motor Kv: 400KV RPM/Volt
NO-Load Current(IO/10V): 0.38 Amps
Motor Resistance(RM): 0.135Ohms
Max Continuous Current: 40 Amps
Max Continuous Power: 1480 Watts
Weight: 152 Grams (4.63 oz)
Outside Diameter: 48.8 mm (1.92 in)
Shaft Diameter: 3.98 mm (0.16 in)
Body Length: 32.17 mm (1.27 in)
Ovrall Shaft Length: 36.5 mm (1.44 in)
Max Lipo Cell: 10s
Peak Current: 56 Amps (2 seconds)
Peal Power: 2070 Watts (2 seconds)
Motor Timing: 5deg
Drive Frequency: 8kHz
Weight including packaging
250g
Data Chart
View Scorpion M-4010-400KV Data Chart
Full Dimension
View Scorpion M-4010-400KV Full Dimension
Additional!! Scorpion High Performance Tools Round Head Hex Driver !
We are proud to announce our new additional Scorpion High Performance Tools – Round Head Hex Series for all RC enthusiasts.
With our hollow core design and made by Aluminum Alloy, we are able to keep the tools very light weight. They are also featured with Scorpion Signature color Gold and Black to keep them stylish and light weight at the same time.
High-Performance-Tools-Round-Head-Hex-Se
We have 2 different size available:
Scorpion High Performance Tools – 1.5mm Round Head Hex Driver
[15_RHex_Driver]
$11.99
RCHR-A1a-Scorpion-1.5m-Round-Head-Hex-Dr
Good news to all RC enthusiast, let us introduce to you: Scorpion High Performance Tools.
We understand how important it is for RC enthusiast to have the tools with you guys on the field. Swapping parts on and off, getting the right parts and setting for your RC car, helicopter or airplane to get the best performance. Scorpion High Performance Tools is designed with RC enthusiast in our mind, the hollow core with aluminum alloy design allow us to make the tools very light weight without losing strength and durability.
Specifications
-Ultra light weight hollow core design
-Handle made by Aluminum Alloy
-Screwdriver head made by HSS(High Speed Steel), build for wear and distortion
-Anodized aluminum handles with knurled grip
-Professional quality
66g
Scorpion High Performance Tools – 2.0mm Round Head Hex Driver
[20_RHex_Driver]
$11.99
RCHR-A2a-Scorpion-2.0mm-Round-Head-Hex-D
They are now available at our online store, please visit here
Source: RcHeliResource Voir l’article complet
