Chris Reibert unboxes the Goblin 570
Check out this vid shared by Chris Reibert. Join Chris as he unboxes his Goblin 570 for the first time. Click through to see what you get in the box. Enjoy the vid everyone.
SAB Goblin 570 Unboxing Review by Chris Reibert
Click here to view the embedded video.
Come join me as I open up the new Goblin 570 kit and check out all the goodness inside.
Gobln 570 SPECS:
• Main rotor diameter: 1278 mm (with 570 mm blades)
• FBL System
• Main blade length:550 to 575mm
• Tail rotor diameter: 260 mm
• Tail blade length: 95 mm
• Main shaft diameter: 10 mm
• Spindle shaft diameter: 8 mm
• Weight including electronics: 2400 g (excluding batteries).
Special Features:
• Full carbon boom
• Battery tray 6S and 12S
• Inside carbon rod
• Dampened tail system
I will be using:
RADIO: Futaba 8FG
SERVOS: MKS HBL950 cyclic servos / MKS HBL980 tail servo
GYRO: iKON flybarless control system
MOTOR: Scorpion HKIII HK4025-1100KV
ESC: Castle Edge HV120 ESC
BEC: Castle BEC Pro
BATTERY: Pulse 5000/5500mAh 45c 6s Lipo
Click HERE to view pics of the unboxing.
Source: RcHeliResourceVoir l’article complet
