firmware dX7S 1.03
Je n'ai pas vu de commentaires la dessus,et pour ceux qui comprennent quelque chose à l'anglais
Version 1.03
24 September 2012
Software Features
• Automatically corrects sub-trim and travel for models created in version 1.01 and
earlier after prompting the user. This is functional both for models already in
your radio, and for any you import from an SD card. You should always verify
operation of a model when making any updates prior to flying it.
• Enabled ability to configure inactivity timer
• Enabled dimming control of the orange Spektrum LED for night flying
Software Corrections
• P-Link Master Trainer mode was using trainer data for channels GEAR and
higher.
• When a channel is reversed the endpoint adjustment worked on the opposite
side from what was expected.
• Improved French translations.
• Added SD logfile indicator to main screens.
NOTE: This change affects sub-trim and travel of existing models and ones you will
import. You should double-check sub-trims and travel on any reversed control surfaces
in both airplanes and helicopters when using models created in version 1.01 and earlier.
