le nouveau DT600E Prototype en action
A video of the new DT600E Prototpye in Action,
The DT600E Specifications are:
Length: 1256 mm
Height: 388mm
Width: 202 mm
Main Rotor Length: 600mm
Main Rotor Diameter: 1350mm
Tail Rotor Diameter: 263mm
Motor Drive Gear: 14T (13T and 15T for your option)
Main Drive Gear: 128T
Autorotation Tail Drive Gear: 121T
Tail Drive Gear: 27T
Drive Gear Ratio: 1:9.14:4.48
Weight (with Motor): 2300g
Accessories:
DT600E Kit x 1
690 3G Carbon Fiber Blades x 1
HD-1209TH Digital Servo x 3
Motor: Scorpion HK-4025-550KV (5mm Shaft)
ESC: Hobbywing Platinum-120A-HV-PRO
Radio transmitter and Electronic equipment required for assembly:
Transmitter: (7-channel or more, helicopter system)
Receiver: (7-channel or more)
3G Flybarless System x 1
Battery: 12SLi-Po 2600~3500mAh
http://www.dt700e.com/
