Nouveau Miniature Aircraft : Whiplash
hello ! :)
Le prototype du nouveau MA "Whiplash" pointe le bout de son nez au salon de Toledo !
mawiphlashelectric1.th.jpg mawiphlashelectric2.th.jpg whiplash.th.jpg whiplash2.th.jpg
Il y a aussi quelques info sur le site officiel de MA :
http://miniatureaircraftusa.com/index.p ... cle&id=140
Whiplash features:
- Designed by Bobby Watts and Chris Lund
- Nitro and Electric, flybarless or standard versions
- Nitro/Electric kits are nearly identical, with only a few parts being different
- Innovative auto-rotation unit which increases motor torque and provides a smoother model
- Sturdy 2mm carbon fiber main frame
- Ultra Simple light weight design
- CNC aluminum bearing blocks with oversized bearings
- True T-6061 aluminum components
- Direct controlled eCCPM (120 degree)
- CNC aluminum boom clamps
- 124T, 11mm thick CNC delrin main gear
- 8.27:1 gear ratio stock for Nitro Model, (7.75:1, 7.29:1 available with no additional changes necessary)
- Electric model will support (9.53:1, 8.86:1, 8.27:1)
- 9mm head axle
- Full ball bearings
- 22mm light weight aluminum tail boom
- Innovative torque tube system which allows ends to be re-used if damaged in a crash (tube sold separately by itself)
- CNC Aluminum swashplate w/high end heim ball
- Carbon fiber tail fin
- Painted canopy by CanoMod
- Delrin tail drive bevel gears
- CNC aluminum main and tail rotor grips
- Optional gear ratios available (nitro and electric)
- Designed for simplified build and repair
- "Adjustable pinion, non adjustable mesh" frame set, which allows flexibility for various motors, but minimum hassle for setting gear mesh
- Innovative system for setting the main shaft "slop" which does not require a collar or shim
- Innovative landing strut system which reduces weight and makes repairs much easier
- Motor mounts (electric) and upper pinion bearing(nitro) both bolt to the main shaft bearing blocks, giving an ultra rigid drivetrain
- Oversized fuel tank which allows up to 10 minute flight times if desired
- Up to 10% bigger than most models on the market, which makes visibility much easier during flight
La classe 90 il n’y a que ca de vrai, depuis le temps que l’on attend cet helico, en espérant que l’on puisse mettre un 120 :idea: dedans histoire de faire de l’ombre à l'électrique mais je pense que cela n’est plus possible aujourd’hui.
Philippe
L’avantage indéniable!!!
Pendant que tout le monde s’acharne sur les T-Rex en tout genre, les Outrage à profusion, Gaui, bidule truc, avec un M.A. on a l’exclusivité sur le terrain, rare sont ceux qui vole en M.A.
Je l’ai vue au sympo ce week-end, j’étais le seul à avoir un Miniature Aircraft pendant que les autres me disait que mon Furion était trop cher parce que 600€ au lieu de 300€ pour la même classe, ce que l’on m’avait clairement dit la bas.
Je ne suis pas un super pilote qui vole à 10cm du sol, mais question puissance l’helico était vraiment tout seule dans les classe 600.
Chez M.A il y a ce petit quelque chose en plus que les autres machines n’ont pas, ca vaut bien 300€ de plus non ?
Philippe
De toute manière l'argument du prix se justifie vachement moins quand tu demandes vraiment quelque chose à la machine, Si tu sais ce que tu veux, tu sais choisir si tu as besoin d'une machine qui prend 100 vols de 3D dans la gueule sans bouger, ou d'un truck qui coûte rien et ou tu changes de pièces tous les 10 vols.
Quand je vois celui de Npap, (de Furion 600) je me dis que c'est bien le seul 600 hors logo, qui fait sérieux dans la durabilité.
Ah que oui!!!
J'en suis raide dingue de mon furion...la méca ne bouge pas..une fiabilité à toute épreuve !!!
D'ailleurs des que le 90 sort il sera mien, c'est sur!!!
Va ya voir du monde de sorti cet été: le Whiplash, le Rave ballisitc, le logo X, le Gaui X7....y'a de la guerre "marketing " en perspective!! Pourvu qu'Align ne nous ponde pas un nouveau T700 aussi !!
Apparemment d’après ce que j'ai compris, il semblerait que la roue libre soit en prise sur le pignon moteur et non sur la couronne, à la manière d'un protos.
ça semble intéressant avec pas mal d'innovations comme bécane :mrgreen:
regardez le diamètre au niveau des roulements de la cloche.
  npap a dit :
Ah que oui!!!
C’est agréable d’être souvent le seul en Xcell pourvu que sa dure, même le 450 on le vois jamais et pourtant en vol c’est une bombe bien plus léger que le T-Rex 450 Pro.
Par contre sur le furion 6 FBL, la courroie c’est arraché deux fois, ce sont les crans qui avait étés arrachés, depuis que j’ai baisser les limites du gyro plus rien ne bouge.
D’un autre cotés, la configuration n’est pas original ceci pouvant expliquer cela.
Philippe
