Video flybarless futaba CGy 750
  • Réponses 118
Vu sur helifreak.
Si c'est vrai les gars avec des spektrums risqueraient d'avoir un sbus moins cher et plus pratique que le Futaba, un comble :lol:
Ca fait presque peur en fait ....
Few clarifications:
1. This is NOT the Futaba-made adapter; it's a product by another company with much broader capabilities. The Futaba one has not been announced yet.
2. Pricing is not final yet
3. This adapter will replace the Spektrum RX, you will only need satellites
It's in testing, and I can't disclose some of the stuff. Nevertheless:
* 3x Spektrum satellite in
* 1x S-Bus out
* 1x PWM out (can also be used for BEC feed in, or BEC + PWM with a Y-connector) for stuff like Switchglo
* BEC voltage, RX quality logging (possibly BEC current as well - not final)
* 1.3"x1.3", very light.
* USB port for setup and upgrades (no adapter required)
* PC control and configuration software
* HV (up to 3S)
There are some more advanced stuff for this unit in the pipeline, related to CGY programming capabilities, DSMX, telemetry, etc. I'll have more details nearer the release.
You will need satellites; however:
1. If you use DSMX it's only one satellite
2. It essentially replaces a fullsize Spektrum RX, and the Futaba-to-PWM encoder, and also does some other stuff which I can't talk about at the moment. In other words, this unit will come out $10-$50 cheaper than going with the Futaba encoder, have minimal wiring (unlike the patch cables you'll need to run with the Futaba PWM encoder), and many programming options.
One final thing - the same unit could be used to connect multiple Spektrum DSM2 satellites to BeastX units.
First batch should be available at the beginning of April, right when the CGY750 hits the market.
toutes les infos passent par le cable SBus, elles sont ensuite décodées par le CGY.
Les 3 voies du Rx ne servent pas, sauf fonctions spéciales (train rentrant,...)
Moi j'utilise un 8 voies + Sbus...eh ben je n'utilise aucune des 8 voies PWM !!! j'aurai du prendre un 3 voies mais il n'etait pas encore dispo a l'époque.
Fabrice
