C'est peut etre les fetes, mais il faut peut etre arréter de croire au pere noel :whistle:
Vu l'ensemble, en se basant sur le nine solo et compagnie, il fallait bien se douter qu'il ne sortirait pas a 50€ :dance: :dance: :dance:
C'est bizzare que sur l'align, la batterie ressort du modele, alors que sur les modeles des autres marques, l'accus une fois en place est camouflé dans la bulle, choix plus pratique qu'esthetique :think:
Dommage pour eux qu'ils loupent les ventes de noel :angry-screaming:
  • Réponses 74
Nouveau jeu de photos, ca se précise :
(clicker pour agrandir)
Trex 100 is about to ready !!! here are some more information and pictures for you.
Trex 100 is really light with only 32g flying weight.
The flybar is under the main blades with soft plastic material
Mode 1 et 2
165317_496361724543_194493419543_5908096_299153_s.jpg167191_496361649543_194493419543_5908095_7997653_s.jpg
A 3.5 mm hole for the simulator cable when you use it to play the flight simulator.
A screen on the transmitter to show you the charging process and the battery status
‎2.4G Transmitter with AFHDS. Uses with 4 AA batteries
Charging plugs are at the side of the transmitter. You can simply plug in the battery for receiver to charge from the batteries in the transmitter.
For charging the transmitter, we use the mini USB plug which you can find it common everywhere.
How to switch from Mode 1 into Mode 2?
Simply release the 8 screws and switch the sticks position and the transmitter will automatically identify if this is Mode 1 or Mode 2.
To switch from Mode 1 into Mode 3, simply push 2 trims inner and turn on the power. You can release after you hear a long beep sound and this mean it is sucessfully switch into mode 3.
To switch it back into Mode 1, do then same thing and you will hear a short beep sound.
We use the DC brush motor. with the tranditional multi-gears servo with the servo motor at the front of the PCB
Blue aluminum alloy main shaft
Ca va faire un carton !
Voila il sera très vite dans vos mains :)
en 2,4Ghz il faut parfois faire de cette façon pour l'appairage .. car il n'y a pas de Binding à faire et il se fait automatiquement de cette façon ....
ba j'trouve ca vraiment pas top ,surtout ca peut donner des mauvaises habitudes :snooty:
:? donc si un gars à une 2.4 déja allumée ,
on branche notre trex 100 ....le gars peut prendre le controle ?
si c'est le cas ,c'est carrement pas trop..."securitée" ! :think:
enfin bref...il est mimi ce ptit trex :mrgreen:
bye
Pierre
Salut Pierre,
En fait sur ce genre de petit moustiques, le "bind" se fait automatiquement a l'allumage de la radio. Elle "bind" pendant 2 secondes et après basta, donc si tu allumes radio puis hélico, le temps que l'hélico démarre, la radio n'est plus en mode binding.
Donc si quelqu'un a sa radio allumé (depuis plus de 2 secondes) et que tu allumes ton T-100, ca ne bindera pas ;)
Je pense que si il y a déjà quelqu'un en vol, la radio est bindée et du coup ne se bindera pas sur un autre modèle.
Donc pour avoir 2 hélicos sur la même radio il faut que les deux hélicos soient en mode bind au moment où tu allumes la radio. Une fois que c'est fait il n'y a plus de bindage possible pendant la durée du vol.
Ce n'est que mon avis, mais je pense que c'est ça ;)
Edit : Posté en même temps que coom 8)
Totoche
La seule différence que je vois est le double chargeur de lipo et son cable usb:
http://www.fxmodelrc.com/products/t-rex ... uper-combo
Contenu Pack Super Combo Align T-rex 100 :
- Kit T-rex 100S
- Radio AT 100 2.4GHZ x1
- Batterie Li-Polymer x2
- Piles Nimh x4
- Chargeur+Cordon de charge USB x1
- Cordon simulateur Radio/PC x1
- CD-ROM Simulateur x1
- Tournevis x1
http://www.fxmodelrc.com/products/t-rex-100s-combo
Contenu Pack Combo Align T-rex 100 :
- Kit T-rex 100S
- Piles Nimh x4
- Tournevis x1
Par contre pour les prix :naughty: ya eu un problème de conversion $ <--> € dans le mauvais sens ? :mrgreen:
Sur la plupart de ces engins le binding se fait en branchant le récepteur en premier on attend qu'il se mette à clignoter et ensuite on allume l'émetteur en pressant un des manches jusqu'à ce que ça bipe ou éventuellement autre bouton(comme plein d'autres radio 2,4). En pressant l'autre manche cela donne un mode débutant ou expert (dual rate).
Bon, ça fait quand même cher l'autocollant align, quand on trouve des équivalents pour moins de 50€ à HK :
http://www.hobbycity.com/hobbyking/stor ... tegory=360
Et je suis pas sûr que l'autocollant align fasse une grande différence dans les qualités de vol d'un engin par ailleurs assez bien coté :wink:
Ce sont deux micro FP avec barre de bell à 45°. Que l'une soit au dessus des pales et l'autre au dessous ne va pas apporter de changement fondamentaux. D'ailleurs sur les premières photos, elle était au dessus aussi sur l'align. Et à moins de 50 euros, c'est avec la radio : http://www.hobbycity.com/hobbyking/stor ... duct=10998
Sans radio cela tourne à 30 €.
salut à tous, bon ben j'ai eu le mien il ya deux jours, c'est sympa mais bon au bout de deux trois vols, à partir de trente secondes : plus assez de jus dans l'accus pour gerer l'anticouple et la il tourne sur lui meme,enfin bref c'est très limité et je suis déçu, pourtant ça vole bien mais juste trente secondes !!
  • 1 year later...
J'ai reçu le mien il y a 2 jours.
Ca vole carrément mieux qu'un DF #4 que j'ai eu il y a 2/3 ans.
On tient le stationnaire très longtemps (pas de problème pour poser la télécommande et boire un coup).
En revanche, j'ai l'impression d'avoir le même problème que manumx... En fonction de la décharge de la batterie, soit il est stable, soit il tourne (dans un sens ou dans un autre quand on met + ou - de gaz). Et la translation lente est difficile à faire sans avoir à corriger l'AC et le cyclique latéral...
Je vais essayer de comprendre pourquoi.
Néanmoins, la qualité est excellente. J'ai pris Align en partie pour la marque, pensant que ce serait une valeur sûre. Je ne suis pas déçu.
Il ressemble beaucoup au Solo Pro, mais en regardant de plus près, ce n'est pas du tout la même chose. D'autant que pour le même prix que le Solo Pro, il est mieux équipé. Il a de nombreux atouts (charger la batterie grâce à la radio, le chargeur USB pratique avec un adaptateur iPhone sur secteur ou allume cigare, le simu)...
Pour 100 petits euros, c'est très complet, très solide et sûrement une très bonne base pour dégrossir un pilote débutant avant de passer sur quelque chose de plus sérieux.
Bien à vous,
Rayman
